rev limiter on kid atv
Old Jan 30, 2004 | 06:52 PM
patrologr's Avatar
Default rev limiter on kid atv
Hello.Anyone know if the atv kid type aeon,quasar,alphasport,macbor,asian mini quad etc,have any type of rev limiter?????
I have a kid atv and dont run more that 25 mph .
Thanks.
Old Jan 30, 2004 | 08:59 PM
spike99's Avatar
To help us provide accurate advice, can you provide the exact year, brand name and engine cc of the mini you want information on.
Old Jan 30, 2004 | 09:34 PM
patrologr's Avatar
My quad is a UNILLI CX 50,you can see on www.unilli.com
Is the same that aeon cobra,macbor,alphasport etc.I bought on 2003 and mount minarelli motor,very similar to Yamaha Jog and I think that same that Polaris scrambler 50.
Thanks.
Old Jan 30, 2004 | 10:44 PM
spike99's Avatar
If your mini is "the same" as the Scrambler 50 model, review these previous posts:
Search Engine - found 1
Search Engine - found 2
Search Engine - found 3
Search Engine - found 4
If you need to find more info on the other brands you listed, you can use this forums search engine to search for historical info. To use this forum's Search Engine, select the "search" sheet at the top of this panel and play around with its various options.
Hope this helps...
Old Jan 30, 2004 | 10:52 PM
oldyeller's Avatar
I doubt it has any limiters you haven't found.25 mph is pretty fast for a stock 50.Most 90s will only do around 30 mph with all limiters removed.
Old Jan 31, 2004 | 07:16 PM
patrologr's Avatar
Ok,my engine is identical that scrambler 50.I can see on part list that polaris and I confirm that.Any more advice??
Thanks for advanced and regards from Spain.
Old Jan 31, 2004 | 11:51 PM
Mars's Avatar
25MPH is it kid. My grandson has a 2001 scrambler 50. There is only the throttle limit screw on the 01~03. I think they sell an aftermarket CDI (increasedredline) box that can be bypassed. You can change the gearing for more top speed but without clutch and CDI mods It will be slow out of the hole.
I think the 04 comes with a removable limiter in the CDI.
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
