HRC kit of not??
Old Jan 31, 2004 | 03:16 AM
jasontrx450r's Avatar
Default HRC kit of not??
I am consider getting the Honda TRX 450R..i was wondering if i do get it should i have the HRC hop-up kit installed?
Old Jan 31, 2004 | 03:43 PM
learning2fly's Avatar
I am going to have the HRC kit installed. It is supposed to add 13-15% HP. I still think an aftermarket exhaust/header may be better than the modified spark arrestor that is part of the HRC kit. I am going to wait a few months on the aftermarket pipe though, I want to see what is out there.
Hope this helps.
Old Jan 31, 2004 | 05:46 PM
racerjohnbf's Avatar
Hey jasontrx450r, what type of riding do you plan to do with the 450r? Are you planning to race it?
Old Jan 31, 2004 | 05:54 PM
Mostly trail riding...at some point i am planning on modify it to race..i know that the HRC kit includes an air box lid with a hole in it which would not be good for trail riding...but i was wondering even though the HRC kit does include different jetting if i could keep the stock air box lid with the rest of the HRC kit
Old Jan 31, 2004 | 05:57 PM
SporTrAx's Avatar
the hrc kit adds 13 %-15% HP isnt it around 7%-8% HP
Old Jan 31, 2004 | 06:40 PM
SporTrAx- That is what I've heard. May not be right though. Hard to say without a dyno. I'm not sure what the stock jet is, but the HRC jet is a 185. The airbox is opened and the spark arrestor is opened up a bit. I wouldn't think 13% would be all that unreasonable though.
In the dirtwheels article, the stock 450R was 37HP and 40HP with open airbox, 190 jet and WBros pipe. This is roughly 8% if my numbers are correct. That was without the HRC cam though. I had heard the HRC kit would add 13% to the stock 37HP. (41.81)
Taking a guess here, but I would think the Aftermarket pipe on the HRC system (cam, airbox, needle) would be better than the HRC spark arrestor. I would think at this point the jet would be anywhere from 190 to 200 though. I really wish someone would dyno the 450R with the HRC kit installed and then with an aftermarket pipe. I think the end results will be 1-2 HP lower than a YFZ with GYTR slip-on, jetted etc. The YFZ in that config is 44 HP, I would be happy with 42 HP though.
jasontrx450r- One would think it would run rich with the HRC jet and airbox lid on. It would need more air.
Old Jan 31, 2004 | 07:00 PM
I would say ride it stock for a while first and then decide if u want mod it or not. If, or more likely when u decide to mod it the aftermarket companies will probably have cam kits and full exaust systems that will perform better than the HRC kit. Just my 2 cents.
Old Jan 31, 2004 | 07:03 PM
Thank you for your 2 cents racerjohnbf..LOL[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 31, 2004 | 07:08 PM
Warranty is something you may want to consider as well. The HRC kit installed by the dealer will not void the warranty from what I have been told. If you install it yourself, it will. I would definitely check with the dealer though.
