fan motor
Old Feb 1, 2004 | 05:29 PM
xxxracerxxx's Avatar
Default fan motor
i want to take the fan motor off to save weight i mostly ride fast will the motor over heat with out it
Old Feb 1, 2004 | 06:25 PM
trailrider500's Avatar
Default fan motor
It might run hotter then normal, and when you slow down it might start to over heat... The hotter it runs the more top ends you will go through....
I would just leave it on it don't weigh that much...
Old Feb 1, 2004 | 06:40 PM
Default fan motor
i will then thanks[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 2, 2004 | 12:49 AM
fishslab's Avatar
Default fan motor
There are guys who do it. You need to look into some of the radiator addatives that help cool it down like Water Wetter or something. Do your homework and be careful
Old Feb 2, 2004 | 07:50 AM
ftwflh's Avatar
Default fan motor
I wouldnt do it! there are better things to take off to loose weight.Like the starter .
Old Feb 2, 2004 | 09:22 AM
Default fan motor
ya i do have water wetter
Old Feb 2, 2004 | 09:24 AM
Default fan motor
i have my starter, battery, oil pump /oil tank, and all the metal stuff on the frame cut off that i don't need
Old Feb 2, 2004 | 09:28 PM
scootergptx's Avatar
Supersock
Hired Gun!
Default fan motor
For no more than the fan weighs, and the chances you'll take if you remove it, just diet and lose 3 pounds.
Old Feb 2, 2004 | 09:41 PM
tbsleeper's Avatar
Default fan motor
i wish mine had a fan!!!
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
