head gasket??
Old Feb 2, 2004 | 04:31 PM
javex's Avatar
Default head gasket??
my oil level went up after a ride today. also, i smelled burning rad fluid and some steam was coming out my exhaust after i turned off the engine. dropped the oil in my engine and it was milky white. think it is a bad head gasket or base gasket? no water or oil coming out the weep hole. i order a head gasket, base gasket, water pump seals and impeller shaft.
Old Feb 2, 2004 | 05:22 PM
DuneMe's Avatar
Not base gasket.
Sounds like head gasket if you are getting it in your exhaust. Might as well replace the base gasket since you are doing the head gasket though.
I was getting milky oil too so, I am replacing my oil pump shaft seal. Wanted to get it done this weekend. Other things got in the way.
Old Feb 2, 2004 | 09:53 PM
javex's Avatar
no water "channels" running through the base gasket? if so, i don't have to buy another gasket. this machine is new, just got off warranty, base gasket should still be good like all other gaskets and seals .. [img]i/expressions/face-icon-small-frown.gif[/img]
Old Feb 2, 2004 | 10:16 PM
ThePunisher's Avatar
Hey Mark I don't think it is your water pump seal. I am pretty sure you have a headgasket problem also.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 3, 2004 | 12:02 PM
DuneMe's Avatar
Punisher:
My coolant is fine but, my oil has coolant in it. My understanding is that was typically water pump shaft seal? Did you have your head gasket leak that way?
Old Feb 4, 2004 | 12:40 AM
DuneMe's Avatar
Tony. . . where are you?
I plan on replacing the water pump seal but, want to know I shouldn't worry about the head gasket too!
Old Feb 4, 2004 | 12:49 AM
Majorecho's Avatar
When my oil went milky it was the seals on the shaft and the shaft itself that had worn out. My coolant level had dropped quite a bit in the resevoir. In the past I had a headgasket leak and in that case I had no oil or coolant mixing just the level in the reservoir over flowed . Not saying it can't happen differently , this was what I experianced with my issues, The bike is now over 4 years old.
Old Feb 4, 2004 | 02:10 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
javex, that does sound like the head gasket, the water pump seals seem to go slowly and I've never heard of the steamy exhaust except in head gasket cases.
Have you noticed if your fan is still in working order? could it be you overheated?
Old Feb 4, 2004 | 02:26 AM
Usually Mark the only way you get Antifreeze in your oil is if it leeks past the head gasket at timing chain side. Try replacing the seals and shafts first though and see what happens.
Old Feb 4, 2004 | 02:54 AM
DuneMe's Avatar
Ah, yep. . . that makes sense.
In your experience would I see power loss with that?
The 8itch of it all is that my riding area is 4.5 hours away and a weekend trip. If I don't get it fixed by the next trip I may end up with down time while on the next trip [img]i/expressions/face-icon-small-mad.gif[/img]
I'll get the water pump seal fixed and try to ride it around a little to see if anything shows up.
Wonder if I pull the valve cover if I can see anything.
Thanks
