Hard faced rockers
Old Feb 4, 2004 | 04:30 PM
Sandrider503's Avatar
Default Hard faced rockers
I was told by LRD performance that I would need hard faced rockers with the stronger valve springs I installed. Is this true I have R/D chromoly valve springs and a WhiteBrothers all around cam. He told me hard faced rockers are about 300.00 bucks. Thats a little too much so if I can get away with it I will.
Old Feb 4, 2004 | 04:37 PM
Quadfather's Avatar
If the cam you are using is advertised as a "drop in cam", you don't have to worry about your rockers. If you use stock rockers in a hard welded cam, it will eat them up. Just because you are running heavy duty springs doesn't mean you need hard faced rockers.
If you are in doubt, I would call the manufacturer of your cam and see what they recommend.
Old Feb 4, 2004 | 05:14 PM
MIA416EX's Avatar
I *think* the WB all around cam is made by WebCam. If this is true, I am 99.9% sure it is hardwelded, and you need hard-weld rockers. If you decide not to put them in (as I didn't), they will eventually wear out, as will the cam, and all will need to be replaced....with hardweld (as I did).
Old Feb 4, 2004 | 09:51 PM
Trailblazer250exrexr's Avatar
o0
Old Feb 4, 2004 | 10:06 PM
wow do you also warship the devil man try listen to something thats not gonna possess you. lol, I got tickets to the Metallica, Godsmack show. I'am sittin nice and close.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Whitelx1
Oct 2, 2015 10:55 PM
exmotocrosser
Sep 26, 2015 08:18 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
