Whats the best mods for speed 85 250R
Old Feb 5, 2004 | 09:04 PM
Bozman505's Avatar
Default Whats the best mods for speed 85 250R
I have a 85 250R ATC it has the stock cyl on its 3rd bore completly ported.
It has a 38mm Mikuni and a K@N with Vforce reeds and a Answer roost boost that I disconnect when racing.
The trike has out ran every stock 4stroke that I have raced and alot of Banshees but there is always a few at the dunes that are running some major HP that can beat me in 300ft.
I was wondering if a Coolhead is worth the money.
Or if I just need to invest in a 310kit or bigger to beat those highly modified Banshees.
Any ideas?
Old Feb 6, 2004 | 05:38 AM
atcpowermadman's Avatar
ok want the most powerpossible get a 11mm stroker crank and a psi powervalved cylender in the 425 piston configuration and tear it up . that sjust my oppinion that swhat i had on my 86 r and i wa suntouchable btu it would have had alot more power if i would have had a decent exaust i had a shi tty dg systemand a old cr500carb on it and it hauled a$$
Old Feb 6, 2004 | 04:44 PM
HA2's Avatar
HA2
ive heard good things about ported 330's and 370's by ESR. that backed with a nice swing arm, paddles, suspension and a rider with the ***** to lay on the throttle even when the front end wants to kiss your helmet, you should have a good platform.
310 would run good but i doubt would run with "highly" modified shees.
Old Feb 11, 2004 | 09:47 PM
LittleBehaus's Avatar
Before you go spending the big bucks,
you should try different size sprockets,
it would be way cheaper. Along with bigger back tires
86 350x
.040 dome-top piston
Cobra Jet Exhaust
K&N Filter
Sprockets
White Brothers Cam and Bigger Carb
Wanna Race
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
Sep 23, 2015 06:23 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
