electric starter is clicking??
Old Feb 10, 2004 | 06:50 PM
supertrapp04's Avatar
Default electric starter is clicking??
My electric starter is clicking and i think is because it is wet but i am not sure so if somebody could help, thanx
supertrapp
87 warrior
supertrapp pipe
Old Feb 10, 2004 | 07:16 PM
rede34m5's Avatar
my neighbor has a 2003 warrior and when it clicks it goes dead soon after so it probably means that the battery needs to be put on trickle charger or a new battery needs to be bought.
Old Feb 10, 2004 | 07:25 PM
Warrior350ripper's Avatar
if your battery is good then your starter is probably startin to g0
Old Feb 10, 2004 | 07:26 PM
or maybe a loose connect
Old Feb 10, 2004 | 07:33 PM
LotusPosition's Avatar
Use some jumper cables and jump the battery from a good one. Chances are that it will start, and you need a new battery.
Old Feb 10, 2004 | 08:08 PM
Thanx all of u i couldn'tfigure it out cause i cleaned the connections but ya i will check that. but I think it might be the switch box cause that is wats makin the noise.
Old Feb 10, 2004 | 08:15 PM
Crotts's Avatar
I think you are talking about the starter relay, what is making the clicking noise. Try using something to jump across the relay, it might have gone bad if its not the battery or connection.
Old Feb 10, 2004 | 10:26 PM
raptorblasterracer's Avatar
ya just recharge the battery or in a worse case get a new one
Old Feb 10, 2004 | 10:30 PM
jpwarrior's Avatar
If its doing it when you wash it or after a stream crossing its prob the same prob i had. I ended up going threw and cleaning all the electrical connections and putting dieelectric grease back in them to water proof them. But it would only act up like that when i went threw water or washed my quad. It was annoy to try and find.
sweaver
11
Aug 18, 2015 03:47 PM
akbrewcrew
Aug 9, 2015 10:54 PM
raceware
Jul 30, 2015 06:59 AM
Chuck188
Jul 17, 2015 02:45 PM
