What is beat for my 2003 mojave?
Old Feb 11, 2004 | 08:40 PM
whitebrothersmojave's Avatar
Default What is beat for my 2003 mojave?
can anyone tell me what is best for my mojave???
Old Feb 11, 2004 | 08:56 PM
kwackermann's Avatar
...... Best for you Mojave-- what would you like to do with it? There are a host of mods- one of the most noticeable would be ditching that airbox and snorkle, this will make the machine objectionably loud, unless closed course racing and the like are the intended use, a good aftermarket pipe would be desired as well. Other mods; a carburetor from a 300ex, acquired from Ebay, although it is a 32mm unit as compared to the Mojave's 34mm unit, it has an accelerator pump whereas the Mojave does not. If you were to go with hotter cams, oversized valves/ big bore kit and a KLR CDI box which has no rev limiter, then a 400ex carb would be the order of business because it's 35.5mm and has an accelerator pump as well.
95wolv
Sep 27, 2024 12:00 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
