Would be ok to go up one tooth
Old Feb 14, 2004 | 02:20 PM
ATLRAPPY's Avatar
Default Would be ok to go up one tooth
I just got all these mods about a week ago (11:1 wiseco first bore, port polish head, stage two cam), and I dont know what sprockets to use. If I go up one tooth on the ront will I lose a lot of bottom? Any suggestions would be appreciated
Old Feb 14, 2004 | 02:32 PM
bansheeesmoker's Avatar
ride it first then go from there. if it tops out to fast then go up one in the front (counter shaft)
Old Feb 14, 2004 | 02:43 PM
ATLRAPPY's Avatar
thats prolly what I'll do instead of going ahead and puttin on new sprockets. I haven't had a chance to ride it because of rain! It is starting to pi$$ me off, I am curious how it is gonna run
Old Feb 14, 2004 | 03:18 PM
Yamaha660R's Avatar
I would go down one tooth or two on the back sprocket. That will raise your top end alittle without taking too much off the bottom.
Old Feb 14, 2004 | 04:22 PM
ALIENraptor's Avatar
you could raise it up 2 teeth in the front if oyu wanted to wth those mods, If you ride open areas if not you could rasise it up 1 (14 tooth) for more speed and stilll pull hard.
Old Feb 15, 2004 | 03:22 PM
ATLRAPPY's Avatar
Since I ride with almost all ds's, I kill them on bottom, but they get me on top. Then I hear sh*t about it and how they are faster. I think I will go with a 15 tooth just for a short while so I can have the edge on top end
Old Feb 15, 2004 | 03:24 PM
BigScary's Avatar
if they are running stock gearing I would run the 14t countershaft sprocket.........
Old Feb 15, 2004 | 03:39 PM
ATLRAPPY's Avatar
ok, thanks. I will try that and post how I did against them.
Old Feb 15, 2004 | 03:44 PM
SLIM660's Avatar
I've trail rode in tight woods with a 15/39 gear with no problem of real bottom end lack. It shouldnt be a problem running one tooth up on the front with your mods and it will give you a little more on top which will help with the DS's. Slim
Old Feb 15, 2004 | 03:48 PM
ATLRAPPY's Avatar
were you have to go back and forth from 1st and 2nd? I dont want to have to keep shifting through neutral
