bolt for the rear shock
Old Feb 15, 2004 | 09:44 PM
BT250racer's Avatar
Default bolt for the rear shock
today when i went out to teh shed and just lookin over my tb i noticed the bolt that hold the shock onto the swingarm was a little bent is this ok and if i need a new one what should the bolt be made out of so it doesnt brake??
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
makin aluminum dimond plate ones
Old Feb 16, 2004 | 12:34 AM
JEFF10049's Avatar
Just went outside and looked at mine it's a grade 5. And looks a little bent also a grade 8 probley would not bend but could possably break since it's a harder metal. I don't see where being a little bent will hurt anything.
Jeff
03 trailblazer 250 RcR stage1 milled head
Old Feb 16, 2004 | 01:17 AM
BigBadScrambler's Avatar
Go with a Grade 8, or Modquads personal favorite.................TITANIUM!!!!
Old Feb 16, 2004 | 01:57 AM
JEFF10049's Avatar
ahhhhhhh yes the TITANIUM.. sounds good to me.
Jeff
Old Feb 16, 2004 | 04:46 AM
rescuediver's Avatar
Yes, if you don't go with the titanium, go with the grade 8 bolts.
Old Feb 16, 2004 | 07:35 AM
Hozed's Avatar
id change it now... if you dont it wont be easy getting it out when its really bent...
just changed the one on my pred to a grade 8 also...
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Bell21
Jul 28, 2015 06:52 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
