Performance CDI for Raptor
Old Feb 15, 2004 | 09:51 PM
02Raptor686's Avatar
Default Performance CDI for Raptor
Does anyone have a performance CDI? I was thinking about getting one for my Raptor, but i wasn't sure how effective they were, so i need some opinions. Also, i have heard of a performance Rectifier..... ARe those any good? ARe they worth the money?
2002 Raptor
Yoshimura full exhaust
K&N Air Filter
JEt kit
686 bore kit
11:1 JE Piston
Stage 2 HOt cam
Old Feb 15, 2004 | 10:00 PM
Yamaha660R's Avatar
I would go with the Big Gun from Rockmountainatv.com
A guy in the Honda forum's got a cdi (rectfier)off ebay his bike wouldn't start with it. Said it never came in any type of box, and had no logo's on it. Reminded him of the stock cdi. So watch for scam's.
Old Feb 15, 2004 | 10:04 PM
Are they very easy to install? Do it yourself?
Old Feb 15, 2004 | 11:14 PM
missgirl's Avatar
I have a question how do you now if you need a cdi or if it will help your atvs performance. I have a 04 raptor with pipe and jet kit and filter. Would it be worth it for me to get a cdi?
Old Feb 15, 2004 | 11:31 PM
Yamaha660R's Avatar
You just un-plug your stock cdi, and plug in the new cdi. Easy mod. Takes like 2 minutes to do it.
The Big Gun CDI claims to add 1-3HP depending on your mod's, and it gives your quad a new, more aggressive power curve. Usually you don't get a cdi unless you have built your motor. But it definetly seems to help the EX's around here that run the aftermarket cdi's.
Old Feb 16, 2004 | 07:18 AM
Ward660R's Avatar
Because they come with a low rev limiter from the factory, the same reason an aftermarket CDI helps DSs out so much.
Old Feb 17, 2004 | 01:02 AM
maddog56's Avatar
No, for 350+ dollars there are other things you can do to increase performance. If you dont mind gettting into the engine, a stage 1 cam and 11:1 piston will wake the engine up for under 275 bucks. Other things to think of are suspension upgrades like new a arms, a new axle, new shocks, etc.
A raptor does not need a cdi until peak hp reaches or approaches 9k rpms. Even with a stage 2 cam you will barely break 8k.
Old Feb 17, 2004 | 01:29 AM
missgirl's Avatar
Thanks for the reply maddog56 if i did go with the stage 1 or 2 cam with 11 to 1 piston would that cut my motor life especally in half? Would i need to get anything else if i did go with that set up.
Old Feb 18, 2004 | 12:41 AM
maddog56's Avatar
Installing a cam and piston shouldnt significantly reduce any reliability or durablity issues with the raptor. stage 2 cams require new valve springs at a cost of about 130 bucks or so. Stage 2 cams are designed to make power at high rpms, which is great for drag racing, duning and the like. Stage 1 cams do not need the valve springs and keep the power and torque in the low and midrange where it is best for trails and playing around.
As far as the piston goes, an 11:1 will still run on pump gas, premium 93 octane. The compression shouldnt give you problems starting it or anything else for that matter. Any higher compression and you will need to run more expensive race gas but will potentially make more power.
bmxatv10
Oct 14, 2022 06:23 PM
Sep 30, 2015 01:37 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
