Help, raptor shifter question
Old Feb 17, 2004 | 01:26 AM
Hossblur's Avatar
Default Help, raptor shifter question
Hey guys, got some new boots and now my big foot(13) doesn't work well with the shifter. I am going to raise it, do I need to adjust the linkage or will it too go up when I adjust the petal up?
Old Feb 17, 2004 | 06:22 PM
Starky's Avatar
Get rid of that linkage junk and get a straight shifter. In the mean time, it's been so long since I had the linkage shifter I don't remember.
Old Feb 17, 2004 | 06:39 PM
Punker660's Avatar
Back the bolt all the way out on the shaft part before the linkage and just turn it. The linkage is better for minor adjustments. It's a pain in the a$$ either way. I'm going to go direct one of these days.
Old Feb 17, 2004 | 07:09 PM
HoundDog06's Avatar
Hoss,
You have to adjust the shifter by moving it one tooth on the input shaft. You won't get enough change by just adjusting the linkage. The linkage will go up on its own when you adjust the input shaft and you can then use the linkage for fine tuning.
~HoundDog
Old Feb 17, 2004 | 10:18 PM
gottago's Avatar
Same thing happened to me when I got my new boots. I wear the same size boot and couldnt get enough adjustment out of the stock linkage, had to buy the direct shifter. You will like it better in the long wrong, no more neutral drops when shooting a hill.
Old Feb 17, 2004 | 10:38 PM
Outlawlawndragster's Avatar
HAving the same problem here . Size 13 Forma Pro . Do the $29.00 shifter work very well? see them in a couple places for sale There the direct shift style
Old Feb 17, 2004 | 10:46 PM
Hayseed's Avatar
Yes, the $29 shifters work just fine. Mine has functioned flawlessly for 1 year. There's getting to be more cheap versions out there too.
Old Feb 17, 2004 | 11:24 PM
Raptor149's Avatar
My Roll Design was rather cheap through my Yammy dealer. Not thirty bucks but not sixty either. I suggest going with a straight shifter. What kind of boots are your new ones? What were the old?
Old Feb 18, 2004 | 12:21 AM
gottago's Avatar
I got the pro design one, works great and I have not had a problem yet. It is the heavy aluminum one. Cost more than $29, but you cant go wrong
Old Feb 18, 2004 | 12:37 AM
Raptorboy4life's Avatar
i ve searched all over and anyplace and dealer in a 100 mile radius doesn't have a (direct into the case) shicter for under $79.99 and i dont know where else to look? is there a website that you guys know of?????
