which is better: Foreman 450s or 450es??
Old Feb 17, 2004 | 11:00 PM
Paintboss63's Avatar
Default which is better: Foreman 450s or 450es??
Is there any difference to speak of?
Old Feb 18, 2004 | 01:06 AM
Coyotechaser's Avatar
Electric shift (thumb) ES , Foot shift (semi-auto) S
Old Feb 19, 2004 | 08:41 AM
Buzzman's Avatar
I prefer the ES. Your feet can stay dry in deep water, you don't encounter the heavy boots shift problems in cold weather, and you can shift easier while standing up in rough terrain.
Old Feb 20, 2004 | 11:52 AM
BSA's Avatar
BSA
The transmissions are identical. The difference is how they shift. The S is with your foot, the ES is electronically with your thumb. I like the ES. It is really well thought out.
Old Feb 20, 2004 | 02:01 PM
kornholio's Avatar
i drive a ES since 1999 and it's a very good 4x4 quad ... nothing can't stop it
electric shift, when you are in 2-3 feet of water/mud it's very useful and the cluster say which gear is in (not on the s) ...keep in your mind the foreman have a hard rear suspension and it don't speed at all ... if your trick is do hard work and ride were he don't have trail is the quad for you ... for approx. 200$ more on the S you can have a ES it's worth every penny thrust me and it's very reliable also you have a emergency shifter if for i don't no what the electric one broke
Old Feb 20, 2004 | 02:11 PM
BSA's Avatar
BSA
Also, the ES comes with full floorboards, an important safety feature.
Old Feb 22, 2004 | 05:58 PM
Quad4Fun's Avatar
As everybody above said. I like the ES, really easy. Just make sure you do not shift through the gears while sitting, it may get stuck in between gears, it will show a - instead of anumber on the display. Usually you just have to rock the quad a little to get it back in gear. I tis posiible to get it stuck and have it be harder than hell to get in back in gear. Doesn't happen very often. I've neve had that happen.
Good Luck
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
shimanok2
Jan 29, 2016 07:37 PM
mark23
Oct 1, 2015 09:57 AM
patrick.oc123
Sep 15, 2015 02:45 PM
