chain
Old Feb 19, 2004 | 01:37 PM
Btyoe's Avatar
Default chain
how do i tighten the chain on my sport
Old Feb 19, 2004 | 08:25 PM
Pushinlimitz's Avatar
Default chain
witch chain ? what year? scrammy sport??? need more info im not shure if there all the same most of them are ecentric shaft
Old Feb 19, 2004 | 08:28 PM
Default chain
i just realized that was your first post welcome to the forums [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 19, 2004 | 08:30 PM
BT250racer's Avatar
Default chain
its was tricky for me when i first did it b/c i had no clue but here. on the back of the swing arm there are two 5/8 nut and bolt u need to losen them and on teh right of the sproket there is 2 hole a half a circle and a hole circle put a strong screw driver on somthin like that in it and push the bike forwards until it pops in even farther then just push teh bike fowards of back wards to get the right about of tightness ( you dont want it to tight it will snap )
Old Feb 19, 2004 | 09:35 PM
quadwrench's Avatar
Default chain
The rear shock needs to be compressed all the way, then you are looking for 1/4" of "flop" in the chain.
I use a pipe wrench to turn the axle carrier - just be careful of the grease zerk.
Old Feb 19, 2004 | 09:39 PM
Jayblazer's Avatar
Default chain
you really want to compress that rear shock i used a ratchet strap it makes it tighten perfect. trust me on this and dont overlook this step...
Old Feb 20, 2004 | 01:01 AM
fishslab's Avatar
Default chain
You also need to loosen the rear brake mount. There is a 1/2 in bolt that mounts the rear disc caliper to the axle housing loosen that as well.
Old Feb 20, 2004 | 09:46 AM
Btyoe's Avatar
Default chain
thanx now i have another question: what is the bolt on top of the recoil for
Old Feb 20, 2004 | 09:52 AM
fishslab's Avatar
Default chain
If your talking about the one I think your refering to, it's to check the timing mark on the flywheel.
Old Feb 20, 2004 | 10:06 AM
Btyoe's Avatar
Default chain
o ok thats what i thought
