Intake Manifold?
Old Feb 19, 2004 | 05:50 PM
Haulinonthedunes's Avatar
Default Intake Manifold?
There are three allen wrench screws holding the intake manifold on. I can get the side ones out but how do u get the top screw out. Do u have to pull the motor out or what? I can't go through the top under the seat because the frame support bar runs right across the top of the screw. So is there a trick or what do u have to do to get the intake manifold off? Any help well be greatly appreciated. Thanks
Old Feb 19, 2004 | 05:54 PM
mystereid's Avatar
It's official, I've been duning for over 30 years.
You will need a ball end allen wrench that allows you to use it at a slight angle.
Old Feb 19, 2004 | 06:16 PM
JDsBusa's Avatar
The top one on mine was pretty tight. It may help if you use a boxed end wrench on the end of the allen for extra leverage.
Justin
Old Feb 20, 2004 | 12:14 AM
jiminok's Avatar
...put your ball end allen wrench in it, apply a little pressure, and then tap the intake with a rubber mallet in a counter clockwise direction--once the intake rotates just a little it'll be a cake walk to get that pesky upper out...[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 20, 2004 | 02:07 AM
BlackHawk's Avatar
I used vice grips clamped onto my ball ended allen wrench which gave me a very large handle to turn it with.
Old Feb 20, 2004 | 09:19 AM
buttfungus's Avatar
This is probably the easiest method!
Old Feb 20, 2004 | 12:26 PM
1BigDSRider's Avatar
Going to try and pull my intake this weekend. How much did one of those ball end allens run?
Old Feb 20, 2004 | 12:35 PM
buttfungus's Avatar
I think I bought a cheap set from autozone for about 8 bucks or so.
Old Feb 20, 2004 | 03:17 PM
Thanks Steve, going to pick a set from sears today. Get me the lifetime quarentee. Hopefully everything goes smoothly.
Old Feb 20, 2004 | 04:00 PM
buttfungus's Avatar
Yep, I should have done that to, but I was in a hurry as usual!..lol
