Intake Manifold?
There are three allen wrench screws holding the intake manifold on. I can get the side ones out but how do u get the top screw out. Do u have to pull the motor out or what? I can't go through the top under the seat because the frame support bar runs right across the top of the screw. So is there a trick or what do u have to do to get the intake manifold off? Any help well be greatly appreciated. Thanks
...put your ball end allen wrench in it, apply a little pressure, and then tap the intake with a rubber mallet in a counter clockwise direction--once the intake rotates just a little it'll be a cake walk to get that pesky upper out...[img]i/expressions/face-icon-small-wink.gif[/img]
This is probably the easiest method!
Going to try and pull my intake this weekend. How much did one of those ball end allens run?
Originally posted by: 1BigDSRider
Thanks Steve, going to pick a set from sears today. Get me the lifetime quarentee. Hopefully everything goes smoothly.
