how deep have you had your sportsman?
Old Feb 19, 2004 | 08:56 PM
yaK's Avatar
yaK
Default how deep have you had your sportsman?
just wondering....owners manual saysto go only to the footrests...but what is every one able to get away with?[just got a 04 sportsman 400!]
Old Feb 19, 2004 | 09:01 PM
Trailblazinrider's Avatar
i dont know, but if ur carb is nething like a tb's there is a one way valve on a hose hangin down from your carb and if water or stuff blockes it up, ur engine will shut off.
Old Feb 19, 2004 | 09:04 PM
NascarFan's Avatar
I have had mine in over the seat. I put my feet on the back rack and the front will float up and help keep the air intakes dry. Hard to steer that way! It's a wonderful thing to get thru a deep hole and have to winch out you buddy.[img]i/expressions/face-icon-small-smile.gif[/img] I love it.
Old Feb 19, 2004 | 09:11 PM
trailrider500's Avatar
Well i am sure the sportsmans are more suited for going through mud water etc then scramblers and i have had my scrambler in water past the PVT cover, with out any trouble... As long as you don't go past the PVT air inlet you will be fine..
Old Feb 19, 2004 | 09:46 PM
rem1100's Avatar
i've had my sportman deep enough to get my butt wet!
Old Feb 19, 2004 | 09:56 PM
BT250racer's Avatar
theres a guy i ride with that has a 500 and he made a lil cover for his clutch that slips right on when he trys to go through the big holes. but takes it off right after b/c the belt needs air to cool off. but anyhow once water gets into the clutch and the belts starts to slip you are pretty much done until u get pulled out. and to let the water out u might want to make a drain plug but what i just do on my tb take off the small tubing piece of tubing thats it hooked onto teh cover and put it and neutral and rev it up for a a lil while and the water starts coming out and drying ( i know it isnt good for the belt but you got to do what u got to do)
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
makin aluminum dimond plate ones
Old Feb 19, 2004 | 10:31 PM
Kushman's Avatar
Had my 400 up to the bottom of the gas tank
I have extended the cvt exhaust vent up (which is the lowest opening) to be able to get that deep
lots of times i'm up to the top of the cvt cover
Old Feb 19, 2004 | 10:56 PM
PolarisOkie's Avatar
This is my brother-in-law on my 500 about a month ago. I have had it about 3-4 deeper(but no pic's of this). Water
Old Feb 19, 2004 | 11:25 PM
csamayfield55's Avatar
had the water splash the top headlight!!! started going through a river and it kept getting deeper and deeper so I finally beached the front end on the bank. So I backed it out and never slowed down
Chris
Old Feb 20, 2004 | 07:51 AM
lovetofish's Avatar
I've had my RSE in over the seat and it is all stock keep it in low range and give the gas you'll pull through almost any thing.Look close to my avatar.
