Head Bolts?
Old Feb 20, 2004 | 08:04 PM
Haulinonthedunes's Avatar
Default Head Bolts?
Can someone tell me how much do u torc the head bolts and jug bolts after u install a new piston? Thanks
Old Feb 20, 2004 | 10:02 PM
BigDaddy331's Avatar
Default Head Bolts?
I believe the service manual calls for 44 ft-lbs however many feel that the spec is high. I just did mine the other day and if your torque wrench is calibrated and you know what you are doing you won't have a problem. You'd be amazed how many people don't know how to use a torque wrench.
Just in case.....
Torque the four main nuts first. Use a cross pattern and start at 30 ft-lbs. then do it at 38 ft-lbs, and then 42 ft-lbs. Your last torque should be right on the money at 44 ft-lbs.
akguy31
Aug 31, 2019 04:34 AM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
