Boost bottle ?'s
Old Jul 7, 2000 | 10:14 AM
Holyman's Avatar
What does a boost bottle accomplish and how. I understand it is used to replace the croosover tube between the carbs, but it seems the tubes feeding the bottle are not oversized so what is the benefit? Or is it another way to spend 40 bucks?
Old Jul 7, 2000 | 10:36 PM
H300F's Avatar
i have a banshee w/ the stock thing and my friend has a boost bottle. It is like a bottle on top of the 2 tubes going into the manifolds. I heard it is posed to boost low-end?? who knows, but i think its bull, and if it isnt bull it makes such a slight difference not worth the money. But i may be wrong??
Old Jul 9, 2000 | 11:54 AM
Katos's Avatar
They work, but on a very low scale. Put it this way, to get a little edge on top end (Lots of us here dragging banshees do this) cap off the two holes. You will sacrifice bottom and gain top. So it must do somthing
Old Jul 10, 2000 | 01:02 AM
mongoose's Avatar
so its like, more volume=better bottom, while capped(no volume)=better top?
Old Jul 10, 2000 | 01:06 AM
H300F's Avatar
yep
Old Jul 11, 2000 | 12:29 AM
mongoose's Avatar
what did you use to cap it off? did you just cut the pipe and clamp it shut?
Old Jul 11, 2000 | 09:11 AM
Holyman's Avatar
There has got to be someone out there who can say exactly what performance improvements can be expected from a boost bottle. So far I'm getting the idea that it's almost useless. Does anyone have one on their ATV and what, if any, improvements have you seen?
Old Jul 11, 2000 | 09:21 AM
CapnShiner's Avatar
I've got a 92 Banshee with Toomey's and the stock crossover tube.
My brother's got a 91 Banshee with Tommey's and the booste bottle.
I've got more low end then him... Go figure.
-Josh
Old Jul 11, 2000 | 10:04 AM
fish_bulb's Avatar
I thought that scenario sounded familiar, jerk! The boost bottle was a wise investment, and I stand behind it whole-heartedly.
...but to add to the discussion, mine rubs on the carb caps and the fuel line. I've almost wore a hole in it. Big bottle-little space.
Fish
'91 banshee
Old Jul 11, 2000 | 12:18 PM
brandon's Avatar
The purpose of the boost bottle is to equalize the pressure between the two carbs thus putting them in better "sync". This is suposed to make throttle response snappier and bottom end more pronounced. From what I have seen and this includes dyno runs, they make absolutely NO difference. I have run a stock crossover for a while, and just recently went to a manifold that doesnt have the crossover intakes made into them and I have noticed no real difference. To block them off get a rubber cap and clamp it over the hole.
