Primary Clutch will not budge........
Old Feb 24, 2004 | 09:09 PM
QuadBuster's Avatar
Default Primary Clutch will not budge........
Howdie all.
I'm looking for some ideas here. I'm trying to get the Primary off my scrammy and she'll not budge. I used the search and I found that everyone seems to be able to get thiers to pop right off w/ either the removal tool or the hitch ball and bolt. I'm putting the king kong on the ball w/ my pipe wrench and I crank her down to the point that if feels as though its ready to break. I've even tried tapping the ball w/ a hammer once tightened and mine's not moving. Anyone else had these troubles before?
Thanks
QB
Old Feb 24, 2004 | 09:18 PM
quadwrench's Avatar
Sometimes it takes a bigger hammer............. [img]i/expressions/face-icon-small-happy.gif[/img]
Are you sure the shank on the hitch ball is long enough that it is bottoming out on the crankshaft? or could it be running out of threads before the shank contacts the end of the crankshaft?
Old Feb 24, 2004 | 09:24 PM
QuadBuster's Avatar
Well..........I've tapped the snot out of it but I was kinda cautious about taking a Sosa swing @ it. As far as the ball and bolt I'm using goes; everything is fine. Looked down the hole in the primary w/ a flashlight to make sure everything was doing fine. When I've got that ball as tight as she'll go, I've still got about 1/4 in. between the base of the ball and the end of primary center so I do have room to tighten up more but that aint happening. I was reluctant to heat it but if noting else works, I'll put a little heat on the shaft between the 2 sheeves. Who knows?..........I'll try being a little more aggressive w/ the hammer.
Thanks
QB
Old Feb 24, 2004 | 10:25 PM
ftwflh's Avatar
spend $20 and get you a puller.
Old Feb 24, 2004 | 10:27 PM
NCScrambler's Avatar
I agree Brad, it is worth the 20 bucks not to mess up that 200 dollar plus clutch.
Old Feb 24, 2004 | 10:50 PM
Kushman's Avatar
put the damn torch away and get a puller before ya hurt something
Old Feb 24, 2004 | 11:54 PM
modquad's Avatar
Here's a trick, but you need to get the right puller first. You pack the thread "chamber w/ grease, then just barely start the threads....OF THE CORRECT CLUTCH PULLER [img]i/expressions/face-icon-small-smile.gif[/img]. Then take a 1/2" impact and drive it in on wide open. It's a really good idea to wear some safety glasses, and an old shirt. Also, remove the belt if you haven't already. That's to keep from getting grease on it. Violent, but they come off.
Old Feb 25, 2004 | 03:16 AM
JEFF10049's Avatar
So modquad is the grease just to protect the threads or is it hydro locking and helping to force the clutch off? the reason I ask is you say to pack it with grease I may be learing a new trick here.
Jeff
Old Feb 25, 2004 | 10:35 AM
modquad's Avatar
It's the power of the hydraulic action. [img]i/expressions/face-icon-small-smile.gif[/img] Bing! Your are the winner! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 25, 2004 | 07:28 PM
QuadBuster's Avatar
I went to the shop and smacked her one good time w/ a 20oz hammer and off she came. Guess I was being too gentle.
thanks for all the help and ideas!
Be good,
QB
