Breaking In A new Wesico
Old Feb 28, 2004 | 11:44 AM
1998trailblazingfool's Avatar
Default Breaking In A new Wesico
I've heard a lot of different ways to breaking in a new piston. Could you guy/ladies tell me what i should do??? The throttle setting and how long?? Thanks
Old Feb 28, 2004 | 12:04 PM
Bradracer18's Avatar
Not sure about a new piston, but a new motor I usually mix a little synthetic oil in with my gas and then just keep it under half throttle for a tank or so of gas. I wouldn't beat on it atleast until I got 2 or 3 tanks through it.
Old Feb 28, 2004 | 12:12 PM
trailrider500's Avatar
Follow what brad said and you will be just fine,,, thats what i do and i never have any problems with my engines...
Good Luck Ride Safe
TrailRider
Old Feb 28, 2004 | 01:12 PM
Hozed's Avatar
well he will want to put extra 2 stroke oil in his tank... mix it richer than normal...
take it easy for a tank or so.. and dont heat up the engine alot... go for short ride.... 10-15 mins at a time and let it cool off before going again.
Old Feb 28, 2004 | 01:51 PM
Doctorturbo's Avatar
GOT BOOST!
Read this: http://mototuneusa.com/break_in_secrets.htm
Very controversial; but I agree with the guy 100%.
Old Feb 28, 2004 | 05:44 PM
tbsleeper's Avatar
thats what i thought doctorturbo u are suppose to ride it hard during hte break in period.
Old Feb 28, 2004 | 06:56 PM
Originally posted by: Doctorturbo
Read this: http://mototuneusa.com/break_in_secrets.htmVery controversial; but I agree with the guy 100%.
here we go with the controversy, I have broke in a few engines and i always do light break ins, i am never hard on my engines during that time. i may change the oil 5 times during break in... If your hard on it then your just going to ware out main caps, cam etc in his case he has a 2 stroke so he only has to worry about the piston, how can you rev something if the piston is not seated? that moto man is full of it IMO... I have been around engines all my life and i have yet to have one fail me with the way i break one in, maybe its because Fords are so good not sure.. I also broke in my scrambler and banshee this way and they are running like new still after countless hours on hard riding...
Old Feb 28, 2004 | 07:30 PM
Well, what i did was ran it idle for 10 min, i premix now, i put in 25oz of oil for 5 gallons of fuel, and than after that run, let it sit over night, than the today i pushed my atv around to get the oil mixed around(just in case) and ran it 1/8 1/4 throttle for like 10 min,cool for an hr and 1/2
than 1/4 to 1/2 for 10 min, let it cool till engine was cool
than 1/2 to 3/4 twice with a cool down period inbetween and i went to change my needle and looked inside and ther seemed to be some scratches up and down, tiny but some, what do u think it could be, i have an exhaust temp gauge and everything was reading below the temperatures that they were supose to be at. So i'm just curious if ther is anything wrong??? please help!!
Old Feb 28, 2004 | 07:36 PM
did you have the jug bored and honed? did you clean the cylinder wall very good before installing the new piston? did you put any break in lube or oil on the piston and cylinder wall?
Old Feb 28, 2004 | 07:40 PM
ya i had it bored another .010 over (previous owner bored it .010) so its now .020 overall bored. And yes we used alot of assembly lube and put in another 5oz of oil(using polaris 2stroke oil) and b4 installing the piston, i cleaned it with soap and water very good, so what could it be
