HELP!!!! 400 won't run!!! QUICK!!!
Old Jul 9, 2000 | 08:48 PM
Steven's Avatar
I went riding yesterday all day on my 99 400EX. It ran fine all day long and never sputtered. I parked it for the night, then when I came back to it today, it started right up. It idled while I put my helmet, gloves, and goggles on, then when I went to go down the road it still went fine. I was only going about 1/4th throtle, but when I gave it to her, she just sputtered, then wouldn't start anymore. It turns over fine, but won't start. So I took it home and started playing with it. I took the spark plug out and there was no spark. I put my friends coil and wire on mine and still no spark, but when we put it back on his, it worked fine. I checked all the fuses. I checked wires. What could it be? Once and a while I will get a little bit of spark but nothing like it should be. Please help. I want to go riding badly.
Old Jul 9, 2000 | 10:06 PM
xWOMBATx's Avatar
It sounds like your plug is oil fouled. That's what happens when I dump too much 2-cycle oil into Banshee's fuel tank. I'dm change the spark plug and if it happens again, it means you're getting oil in the cylinder somehow...and since it's a four stroke, that's not good...means a ring is bad. hope this helps.
-Bat
Old Jul 9, 2000 | 11:12 PM
jeepin's Avatar
Sounds like a stator prob to me.On my warrior did the same thing.We got a new stator and it gets spark now that is about it though.LOL.
86 trx250r.Wiseco .020 piston,boyesen reeds,FMF gold series fatty pipe,power core 2 silencer,DG alloy series nerfs,motion pro twist throttle,motion pro kill switch,Motion pro,clutch cable,PEP easy pull clutch perch and lever,White bro's white power shocks with adjustable res's all the way wround,JD performance +2 A-arms,Fastline braided steel front brake lines,Braking brake pads,uni filter,nac's casesaver,Durablue eliminator 2+2 adjustable axle,Durablue posi loc axle nut.18/11/8 holeshot mx's on mitchell .190 wheels,20/11/9 6 ply razr's on ITP .190 wheels,21/7/10 holeshots on ITP wide off-set .190 wheels.
www.angelfire.com/me3/fmf86trx250r
Old Jul 9, 2000 | 11:17 PM
azrob's Avatar
Test all of your switches: ignition, kill etc. And don't just test them using an ohm meter, swap them too with your friend's 400EX.
Old Jul 9, 2000 | 11:19 PM
azrob's Avatar
Then again, it could be your CDI box.
Old Jul 10, 2000 | 11:56 AM
Steven's Avatar
Thanks for all the replys guys!! I trades CDI's with my friend this morning and it fired right up and ran fine. When I put mine back on it, it wouldn't run again. I guess I'll be ordering an aftermarket rev limiter. Thanks again.
flyin-lowe
Dec 1, 2017 03:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
cornermike
Sep 10, 2015 08:30 AM
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
