2000 Trail Blazer fuel shutoff valve
I currently have 3 Blazers. In the past 2 weekends 2 of them have develooped fuel shutoff valve problems. No fuel gets through. On the trail is were I discovered this on one and in the yard was the other.
Here is the wierd thing: When I drained the tank via the valve the fuel came out faster when the valve was off. Hmmm. So I removed the valve on each machine, cleaned it with air and checke to make sure the valve was turned so the reserve and main fuel worked the way they should. I HOPE this solved the problem. Found no reason for the gas to stop flowing with the valve "ON". But it did until after the "repair". Any comments?
Dear Polaris: Any recalls or service bulletins we need to know about?
