2002 500i question
Old Mar 1, 2004 | 08:13 PM
ferretface's Avatar
Default 2002 500i question
if anyone could give any info on how to make these machines have more power, your input would be deeply appreciated. thanks.
Old Apr 30, 2004 | 07:25 AM
wtb's Avatar
wtb
Did you ever find an answer to your power question,, Mine seems sluggish also
2002 500i 4x4 a/c stock
Old Apr 30, 2004 | 10:01 AM
ferretface's Avatar
i haven't been able to find out much, but on monday i am having a clutch kit installed, i'll let you know how goes.
Old Apr 30, 2004 | 11:31 AM
1wook's Avatar
The 03 have noticably more power, I belive the only engine change was that they went to a 36 verses a 34 carb. A jet kit and a new mufler or the muffler mod should help out allot.
Old Apr 30, 2004 | 09:25 PM
arctic375's Avatar
To make the 02 500 run better you can install the 2003 piston (higher compression), cam(more duration), and carb(bigger). If you need more power look at a Black Magic full exhaust system. All it takes is money!
Old May 1, 2004 | 05:09 AM
ferretface's Avatar
I WOULD LIKE TO THANK YOU GUYS PERSONALY FOR YOUR REPLYS, THIS IS WHAT I'VE BEEN TRYING TO FIND OUT FOR THE LAST FEW MONTHS. I AM NOT VERY MECHANICALILY INCLINED SO THIS IS A GREAT HELD TO ME. THANK YOU VEY MUCH!!! MUCH APPRECIATED!!
Old May 1, 2004 | 08:41 PM
arctic375's Avatar
Your welcome, hoped I helped.
Old May 1, 2004 | 10:54 PM
JohnO's Avatar
I looked into the difference between the 02 Cat 500i and Vinson. What I was told:
Larger carb
Revised valve timing
slightly higher compression ratio
Or in other words, not just a bolt on operation. More than I wanted to fool with.
Old May 8, 2004 | 07:47 AM
wtb's Avatar
wtb
Hey thanks for getting back to me... Any word on the clutch kit,, haven't touched mine yet..
Old May 8, 2004 | 08:30 AM
ferretface's Avatar
wtb, i got my clutch kit put in and semed to help a little. it doesn't seem to lose as much speed when going up hill. I talked to guy who installed the kit and he suggested that i try a bigger piston and a new pipe, so that is the next thing i am going to do, only it won't be done for a couple of weeks. if you would like i will keep you posted on how it turns out.
