Sport Quads Discussions on sport quads.
installing cam and rejetting
Old Mar 2, 2004 | 02:13 AM
mrkfx's Avatar
Default installing cam and rejetting
My sons Raptor has a white bros. slip on r4 silencer. We're going to be installing a Stage 1 Hot cam and a Twin air air filter. My questions are how much work is it to install the cam? And how much jetting will I have to change once I put in the air filter? Any help with this project would be appreciated. Thanks
Old Mar 2, 2004 | 02:51 AM
maddog56's Avatar
The cam isnt too difficult to install, just make sure you have a manual on hand to lead you through the process. Also remember to change your valve lash. I was running the suggested 8 and 10 thousandths lash, but dropped to 6 and 8 as a result of input on this forum. I was running 170/175 with a full ct pipe and stage 1 cam with K&N prodesign kit and no lid. Hope that gives you some kind of reference.
Old Mar 2, 2004 | 09:37 AM
mrkfx's Avatar
maddog, how did you adjust your valve lash and did you have to adjust your needle height also when you rejetted? This is fairly new to us and we're trying to do it on our own.
Old Mar 2, 2004 | 09:39 PM
maddog56's Avatar
i went up one on the needles and out about a 1/2 turn on my air screws.
you can set valve lash with a set of feeler guages, availible from any auto store for a few bucks. you will want to get one that you can bend, not one of the single discs. The exhaust valves are especially hard to reach.
Old Mar 2, 2004 | 09:40 PM
maddog56's Avatar
there is a step by step for checking valve lash on
www.raptortranny.com
Old Mar 3, 2004 | 09:30 PM
mrkfx's Avatar
Maddog, thanks for the instructions. Now if I can only get up the courage to try the install.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
