Clutch Change Help
Old Mar 2, 2004 | 05:41 PM
pads's Avatar
Default Clutch Change Help
I went through the posts and got some hints. I have replaced a clutch on the Quadzilla I had and it was easy. Is the DS as easy? I see to soak the new plates. I have the 60% stiffer springs on order. I just pull the side cover off after draining the oil and coolant.
Then wire tie the cover out of the way.
Loosen the bolts on the basket in a clock pattern.
Remove the springs and cover.
Take notice of the clutch plate order.
Scuff up the metal plates after making sure they are not warped.
Reassemble in the opposite order.
Did I miss anything?
Old Mar 2, 2004 | 06:30 PM
1BigDSRider's Avatar
If you tilt the quad far enough over you dont have to drain the oil. I used a cinder block, under the tires to keep it tilted.
Old Mar 2, 2004 | 06:36 PM
pads's Avatar
Thanks for the tip. Anyone else?
Old Mar 2, 2004 | 06:49 PM
On the Ds there is one clutch plate with smaller tabs. It has to go on last. Its offset from the others. Look for it when removing the clutches.
Old Mar 2, 2004 | 10:19 PM
QUADMAN650's Avatar
I use a sawhorse t tilt my ds over on just place it underneatch the handlebars and also i use small scredriver and clamp them inside he hsoses to keep them from leaking or spilling everywhere
Njrider1230
Jul 29, 2023 05:16 AM
Cummins Driver
Sep 11, 2019 01:22 PM
merryman
Jan 19, 2016 04:29 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
