atc200m parts
Old Mar 3, 2004 | 08:44 PM
pugsley's Avatar
Default atc200m parts
I have a 1984 atc200m 3 wheeler I need the gasket or donut that goes between the exhaust pipe and the cylinder head where the exhaust connects to motor, also the pull start assembly with the cover it only has a round part about 4 inches in diameter that spins around when it is running, also is there a web site where i can look at the parts availible and prices for my 3 wheeler thanks for any help
Old Mar 4, 2004 | 12:21 AM
KNOWSALOT's Avatar
The Facility
The gasket you need is still available from your Honda dealer and doesn't cost but a few bucks. If your dealer carries the cheaper line of gasket kits, you may want to buy that. They usually run about $15.00 and have the gasket you need now...plus have other gaskets for a rebuild when you need them.
Regarding the starter cage.....This too is still available from your dealer. The Honda OEM unit runs about $35.00....but your dealer can also get an aftermarket one for under $10.00.....It's made in China is made of a softer metal but will last quite a while.
I don't know of anywhere on the net that has parts shematics for the ATC models. Honda sellls parts manuals for $40.00, but each manual only covers one model.
1986Vmax540
Jul 9, 2021 09:53 PM
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
