400EX chain removal?
Old Jul 11, 2000 | 02:24 PM
briancwatkins's Avatar
What's the easiest way to remove the chain on the EX. Is the only way by sliping it over the sprockets? I didn't find a masterlink anywhere. Thanks in advance.
Old Jul 11, 2000 | 02:28 PM
Mike300EX-99's Avatar
Stock chains are what they call endless, no masterlink. You can either cut it or remove the swingarm, sucks don't it.
Old Jul 11, 2000 | 03:41 PM
Skunky's Avatar
you don't need to remove the swing arm... Just loosen up the four alan bolts on the end of your swingarm and rotate your axle forward then slip it over the sprocket... Or just cut a link out like i did with my dremel...hehe Now i need a master link for stock chain and the did o-ring chain that is out in the market does not fit.... more than likely the chain streeched too much...
Old Jul 11, 2000 | 10:38 PM
Do you want to remove the chain or just take it off the sprockets?
Old Jul 13, 2000 | 01:58 PM
Mike,
Yes, my intent was to fully remove the chain. I wanted to perform the "Hot Oil Bath" treatment on it. Oh Well!
Skunky,
I think you made a typo. I sort of understood what you did, but the typo got me confused on the fix. You took a link out and I guess tried to insert an aftermarket master-link??? But, the aftermarket did not fit...correct? So, you are telling me not to cut a link out....right?
Hey, thanks fellas
Old Jul 13, 2000 | 03:43 PM
Skunky's Avatar
the typo was not a typo The stock chain is a D.I.D. chain. I tried to get the D.I.D. master link for there d.i.d. x-link chain which is o-ring... The issue is is that my stock chain streeched and the master link would not fit..
Old Jul 13, 2000 | 04:36 PM
Got it, thanks.
Old Jul 13, 2000 | 10:28 PM
Brian, the swingarm removal is a simple procedure, you can also grease your pivot bearing while your at it.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
