thumb throttle, 2 wires in it?
Old Mar 9, 2004 | 05:04 PM
ToppNotch's Avatar
Default thumb throttle, 2 wires in it?
well i was fiddling with my thumb throttle and i saw a yellow wire with red stripe.. and a solid grey wire.. i was wondering if any one knows what these wires are for? and are they supposed to be there. it looks to me like it is.. when i hook a voltmeter up to them i dont see any current going thew them.. the brake light dosent work.. and no headlight but when i hook the VM up to there still no current runs great though.
any ideas? it is a 86 250R Quadracer
Thanks
Old Mar 9, 2004 | 09:28 PM
ToppNotch's Avatar
Bump... any one know?
Old Mar 9, 2004 | 10:48 PM
Mars's Avatar
TPS for timing advance?
Old Mar 9, 2004 | 11:07 PM
Slacker1bob's Avatar
Headlight switch for on/off
ToppNotch's Avatar
make sence no senser in the unit it self.. any effects of it is dis connected?
The headlight switch is above the kill switch on the left side
Old Mar 10, 2004 | 11:44 AM
I already PM you, but for the enlightenment of others I will reply.
The 2 wires running to the On/Off switch can be just spliced together, however then your lights will be on all the time. If you do like I did and only run lights off the high beam wires, then the low beam setting can be used as the Off switch.
skinnyr6
Aug 25, 2023 02:18 AM
skeets44
Jul 17, 2015 01:04 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
