oil change
Old Mar 12, 2004 | 10:55 PM
hondarider300's Avatar
Default oil change
hey, this is a stupid question but... how do u change the oil on the 300ex and how often do u recomend doing it. thanks
Old Mar 13, 2004 | 03:02 PM
honda450es4x4's Avatar
Default oil change
look in your owners manual
Old Mar 13, 2004 | 07:00 PM
Default oil change
i never recieved an owners manual when i bought it... can anyone help me?
Old Mar 13, 2004 | 07:28 PM
250xlouie's Avatar
Default oil change
its really easy. Look under your engine there should be a skid plate and in about the middle of that skid plate there is a bolt , your oil drain plug. Take that out and your oil will drain out the hole(make sure when u take it out you have a bucket under it so the oil doesn't go everywhere). after all the oil is out put the plug back in and on your clutch cover there is a cap that unscrews where you put the new oil in. Put you oil in and screw the cap back in and your all set. I also would recomend changing your oil filter either every time or every other time you change your oil. This is the triangle bolt patter on your clutch cover. take out the three bolts and put the new filter in just like the old one was. As for changing your oil , i change mine about every 5-7 rides. Some people change it more or less then that , its really just your preference. Hope this helped you.
Old Mar 14, 2004 | 10:02 PM
Default oil change
thanks
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
