Does a 300ex have a oil filter
Yes it does. It is on the clutch side of the motor (right side as you sit on it). It has a cover with horizonal lines on it. It has 3 8mm screws holding it on. There is an o-ring sealing it, and a spring pushing on the filter.
the manual says 1.69 quarts. so put in one then 3/4 of another one. crank it up and let run for maybe 3 to 5 minutes kill it let it set for a minute or two and check the oil level without screwing in the dipstick. add oil if ya need it. later
Steeldon
Sep 9, 2015 09:38 AM
