Does a 300ex have a oil filter
Old Jul 12, 2000 | 06:51 PM
Dirttrash's Avatar
I just bought a 300ex and it doesnt have a owners manual. I am going to change the oil and I need to know if it has a filter and were it is located.
Thanks
Old Jul 12, 2000 | 06:57 PM
Y2K300EX's Avatar
Yes it does. It is on the clutch side of the motor (right side as you sit on it). It has a cover with horizonal lines on it. It has 3 8mm screws holding it on. There is an o-ring sealing it, and a spring pushing on the filter.
Old Jul 12, 2000 | 07:11 PM
alibaba's Avatar
just get under the atv and drain the oil. un bolt where the oil filter is (i think on the right side too). put in a new oil filter. then put in 1.5 quarts (i think thats right) in.
Old Jul 12, 2000 | 10:53 PM
hondatrx300ex's Avatar
the manual says 1.69 quarts. so put in one then 3/4 of another one. crank it up and let run for maybe 3 to 5 minutes kill it let it set for a minute or two and check the oil level without screwing in the dipstick. add oil if ya need it. later
Old Jul 13, 2000 | 12:06 AM
radgumby350's Avatar
MAKE SURE YOU PUT THE FILTER IN THE RIGHT WAY OR YOU WILL DO MOTOR DAMAGE!!!!
Old Jul 13, 2000 | 12:10 AM
i have a mint 91 250x & 00 400ex they take the same filter & i buy them at pepboys auto store for $3.99
Old Jul 13, 2000 | 08:05 AM
puddding's Avatar
the filter is a common type....i am told its the same as the xr250 and honda 300 etc....
Old Jul 13, 2000 | 08:23 AM
skull's Avatar
hey I dont have a manual either. does anyone know if the 300ex has tranny fluid? if so how and how often do I change it?
Old Jul 13, 2000 | 09:43 AM
puddding's Avatar
its the same oil as the engine
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
