700 EFI FOULS PLUGS WHEN COLD "HELP"
Old Mar 14, 2004 | 05:46 PM
sneeker's Avatar
Default 700 EFI FOULS PLUGS WHEN COLD "HELP"
Has anyone had trouble with there 700 efi fouling the plugs?
If I don't warm it up real hot it fouls the plugs the dealer says i don't know what to do.
It's been back 5 times there saying i dont warm it up well it's got 30 miles and 8 hrs of run time
it spends more time warming up then running. I need help.
Old Mar 14, 2004 | 07:01 PM
hondabuster's Avatar
Wheres kalamazoo, mn at?
I thought the reason for going to efi, was to eleminate these kinds of problems. It should idle or run wide open and not foul plugs. Something in the feedback loop isnt sending the message. The dealer should be able to hook up the computer and figure it out. If they cant, then they need to call their tech center and come up with something.
Does it have any other symtoms? Hesitation, bog, miss fire, or stumble? Any black smoke in exhaust?
It usually isnt good to let the motors idle for long, but with efi, it shouldn be a problem.
Old Mar 14, 2004 | 07:08 PM
sneeker's Avatar
They say that im not warming it up the dealer called polaris they havent got a clue no trouble codes.
when its cold if you rev it up a little black smoke comes out but not much.
It acts like low spark volts.
Old Mar 14, 2004 | 08:36 PM
WRENCHNNUTZ's Avatar
Check the coolant temp sensor, if it's getting the wrong readings (temp!) the computer will adjust the air fuel mixture causing an overrich OR even a lean condition.
a lot of times it will not even set a code because the computer dont know the TRUE coolant temp.
first thing i would do is check all the connection's first, maybe one loose or disconnected.
Old Mar 15, 2004 | 07:55 AM
mtpockets's Avatar
hey Sneeker,
i noticed you changed States! your signature yesterday said kalamazoo, Nevada, and today it says Michigan!
what's up with that bro?
-MT[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 15, 2004 | 08:35 AM
zorro700's Avatar
try draining the gas and starting over there. As dumb as it sounds a friend of mine ( a logger) accidently filled his bike up with diesel and it would foul plugs and finally burned a hole in the top of his piston. 250 suzuki racer.
Old Mar 15, 2004 | 10:02 AM
sneeker's Avatar
I kept hitting the wrong state it's mi.
Old Mar 15, 2004 | 10:04 AM
sneeker's Avatar
Its new just had gas in it it went back to the dealed the second day after i got it.
Old Mar 15, 2004 | 10:09 AM
SHOTGUN's Avatar
They had the same problems with there snowsleds.
I had 650's and 500's EFI's, everyone else would pull the cord and take off. I was always 3-4 min behind...
I though that would have changed by now....sounds like not.
Old Mar 15, 2004 | 10:52 AM
Polaridoo's Avatar
WRENCHNNUTZ is probably right. Tell your dealer to quit being so passive and lazy and DO something. Tell them to start with the temp sensor because that is probably the problem. One other thing that MIGHT be happening, but I would not put much faith in it is the ignition system (CDI / STATOR / COIL). If you are not getting a solid spark you can foul. Have you inspected the intake system (snorkel and air filter) for any kind of debris or blockages? I know it does not sounds likely, but whatever the problem is, it will probably not be obvious and probably be very simple.
