Where to hook???
Old Mar 15, 2004 | 12:46 AM
bigbamaboy's Avatar
Default Where to hook???
When I double my winch cable back from a ****** block is it ok to hook the the little bar right at the bottom of the radiator cover. If not, were do yall hook to when using a ****** block. I don't want to hook to anything that will tear loose.
Old Mar 15, 2004 | 01:44 AM
AlaskaBoy's Avatar
I usually hook it to the main part of the frame (ie) the biggest tube I can see on the frame with a old piece of web strapping that has a D ring attached to it. I would loop it around the frame and connect it to the hook. I am getting tired of digging this out and am going to mount a permenant D ring.
I have seen in Cabelas a mount for attaching a winch hook to, it is a plate with 2 u-bolts and bolts to the frame and the D ring is attached to the plate. I am going to do this with my Kodiak except I am making my own from some srcap steel plating and getting my neighbor to weld a piece onto it that is drilled to bolt the D ring on, cost is going to be around 5 bucks and gives a firm place to connect the winch cable. AlaskaBoy.
Old Mar 15, 2004 | 02:28 AM
rescuediver's Avatar
Originally posted by: AlaskaBoy<br I am making my own from some srcap steel plating and getting my neighbor to weld a piece onto it that is drilled to bolt the D ring on, cost is going to be around 5 bucks and gives a firm place to connect the winch cable. AlaskaBoy.
Alaskaboy, I built one just like that, works great and like you said. Only cost was what the D ring cost. Lt.Dan
Old Mar 15, 2004 | 02:32 AM
AlaskaBoy's Avatar
Rescue, 5 bucks is better then 20 plus shipping.AlaskaBoy.
Old Mar 15, 2004 | 08:50 AM
bigbamaboy's Avatar
Sorry guys, I'm talkin about is specific to a sportsman. I am asking if it is ok to hook to the bar at the bottom of the radiator grill on a sportsman. If yall dont know what im talkin about go out and look on a sp at the bottom of the radiator grill, there is a bar that has about two or three inches exposed. The hook on my Warn fits right there perfectly, and it seems to be solid, but I was wanting to know if any sp owners hooked there. Thanx
Old Mar 15, 2004 | 03:18 PM
fstrthnu's Avatar
That's what it is there for. I use it all the time.
Old Mar 16, 2004 | 12:48 AM
bigbamaboy's Avatar
Thanx, thats what i wanted to know.
Old Mar 21, 2004 | 09:17 PM
Hilde500's Avatar
Just alittle info , I usually hook there until my hook got in a funny posistion and it broke both screws that hold the radiator solid , clean off had to drill them out
Customer Service #1
May 15, 2020 08:46 AM
Alex G.
Sep 19, 2015 06:34 PM
merryman
Sep 19, 2015 03:15 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
