CC"S Dont mean much!
Old Mar 16, 2004 | 08:35 PM
Shav0's Avatar
Default CC"S Dont mean much!
im about to vent some frustration.
There are alot of people on here who are confused. Just because a bike has more cc's then another dosnt mean its better. If that was the case then the yfz 450 wouldnt touch a raptor, but it does. And that would also mean that a 400ex can beat a banshee, and it cant. And that would also mean that a yz125 dosnt have any power at all, and it does. And that would mean that a 300ex can beat a blaster, and it can't.
Just because somthing has more cc's dosnt mean its better, or faster.
Old Mar 16, 2004 | 08:39 PM
warrior68man's Avatar
Uh....duh....I never said that the CC's mattered.....but how much power and how fast it revs, does. Also 2 stroke or 4 stroke.
Old Mar 16, 2004 | 08:42 PM
Shav0's Avatar
im not even talkin about you,
thats all you see on the forms now, "my 400 can beat your 350 because its got more cc's"
well thats not the case.
like you said, there are alot more things to consieder. like revs and 2vs.4 stroke. im just saying that alot of people try and compare the amount of cc's when really that dosnt show anything.
Old Mar 16, 2004 | 08:44 PM
Shav0's Avatar
and. . . yes you did say
"240 2Stroke Motor
350Twin 2 Stroke Motor"
you didnt say anything about the revs. you just compared the cc's
Old Mar 16, 2004 | 08:57 PM
KILLERCUDA's Avatar
A YFZ can touch a Rap simply the YFZ comes a lil more uncorked than the rap from the factory.
Old Mar 16, 2004 | 09:29 PM
JakalWarrior's Avatar
All things equal, more CCs is better. But its almost never equal. Engine design is very important.
Old Mar 16, 2004 | 09:31 PM
UltimateAussie's Avatar
It also has alot to do with the gearing. Like A banshee can so easily beat say a grizzley even though the grizzly has almost twice as many CC's. becuase the grizzley is designed to pull anything and go anyware. so it needs lower gearing. the banshee has higher gears becuase it is meant for speed and power.
Old Mar 16, 2004 | 10:10 PM
maddog56's Avatar
the grizz is a thumper, the shee a 2 stroke. big difference. about 1.73 ratio.
Old Mar 16, 2004 | 10:49 PM
RoostItUp's Avatar
Dude...you took things way out of perportion! Sure something with less cc's can beat something with more, it just depends on whos making the most power without weighing to much. The larger displacement just means it is more capable of producing larger amounts of HP and torque. The HP numbers of a bike isnt the only factor at all, I think most people are just trying to get the point across that more cc's means it CAN produce more power but DOESN'T mean it will always make more. The new 450's dont have the ability to make the same HP larger displacement engines do BUT they have handling and light weight on there side which helps close that gap in HP between the Rappy. Also the engines put in the 450's are designed to be light and quick revving not for high HP, they don't need all that power for MX.
Old Mar 16, 2004 | 10:56 PM
waynaferd's Avatar
That's exactly why a little Japanese 600cc sportbike can wax, wax, wax a Harley with more than twice the engine size........or HD hasn't figured out how to build a bike yet.......
