E-Ton America Introduces the New 2005 Viper 90 with Reverse
Old Mar 16, 2004 | 08:53 PM
GE4x4's Avatar
Default E-Ton America Introduces the New 2005 Viper 90 with Reverse
FOR IMMEDIATE RELEASE
E-TON AMERICA INTRODUCES THE
NEW 2005 VIPER 90 WITH REVERSE
Spartanburg, SC - E-TON America takes a big leap forward by allowing their customers to move backwards. Introducing the new 2005 Viper 90 now available with reverse, a rare feature found on youth ATVs. Designed for the demanding youth rider ages 12 and over, the Viper90R is simple to operate while offering the power, control and flexibility you would expect from an E-TON product.
Equipped with a powerful, 2 stroke, air cooled engine, the all new Viper90R surpasses the competition as the only sport-styled youth model available with reverse. The aggressively styled Viper90R offers youth riders increased maneuverability on terrain exceeding the performance of other youth ATVs. Shifting into reverse gear is accomplished quickly and easily by using the convenient handlebar mounted electric shift control. In addition to the reverse gear, the Viper90R includes features like a safety tether, safety flag, brake lights and tail lights, advanced rear hydraulic disc brakes and an optional remote shut-off switch which demonstrate E-TON’s focus on creating a safe ATV experience for young riders.
Viper 90R Quick Look Features List
Electric start with back-up kick starter
Engine stop switch for safety with optional remote shut-off switch
Hydra-Disc® Rear Hydraulic Disc Brake
Fully automatic oil injection eliminates the need to premix the gas and oil
C.V.T. (Continuous Variable Transmission) provides even torque through all riding conditions
Adjustable throttle stop and electronically limited speed.
Keyed ignition switch for added security
Safety brake switch. Engine will not start until brake is engaged.
Wide, sturdy wheel-base
"A" arm independent front suspension has adjustable individual shocks for a safer more surefooted ride
Swing arm rear suspension helps maintain traction under rough riding conditions
Parking brake
Quick release seat latch for easy access
On-board tool box for simple field repairs
Tail/Brake light and Horn
Pulsing Front LED
Multi Panel body design
Flag Holder
Oil Tank low indicator light
Old Mar 17, 2004 | 10:44 AM
SANDMAN430's Avatar
did it say how much it's weight is?
Old Mar 17, 2004 | 05:00 PM
GE4x4's Avatar
No, there was no mention of weight, but I can't see it being to much more then there 04 90's.
Old Mar 19, 2004 | 01:03 AM
oldyeller's Avatar
I believe the reverse is electronic so the wieght difference should be nil. The 04s were 209 lbs dry wieght
Old Mar 19, 2004 | 10:42 PM
geo's Avatar
geo
249 lb dry weight for the RXL90R (reverse) according to a brochure i picked up at the Eton booth at Indy (compared to 238 lb for their 70, and 50)
Old Mar 20, 2004 | 12:25 AM
oldyeller's Avatar
Are you sure on those wieghts?A 40lb weight gain is an awful lot of weight even if the reverse was mechanical?Somebody's brochure must be incorrect.
Old Mar 20, 2004 | 02:37 AM
34's Avatar
34
I just picked one up today and the owners manual says 249 lbs dry weight!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
flyin-lowe
Dec 1, 2017 03:18 AM
salixair
Nov 3, 2015 08:25 AM
r1pilot83
Sep 27, 2015 07:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
