Mod motor LT-80 in the dunes. HELP!
Old Mar 16, 2004 | 11:04 PM
FastEddie's Avatar
Default Mod motor LT-80 in the dunes. HELP!
My son was able to wipe out a front clutch in one weekend at the dunes. Has anyone had good luck
with the clutches living in the dunes? It seems that either only having 4 rollers or the higher than stock (9000+) rpm's make the front clutches unreliable. The little 80 motors are always screaming out in the dunes.
Old Mar 17, 2004 | 01:07 AM
LT80's Avatar
LT80 Expert
If sand gets in anything can happen. Did sand get in? We can drill out 6 rollers to utilize all 6 easy enough. I think you should remove the stock snorkle that has the air flow going into the clutch cpver and put a K&N type filter on there.
Old Mar 17, 2004 | 10:43 AM
SANDMAN430's Avatar
our has been fine at the dunes but it is all stock.
Old Mar 17, 2004 | 11:14 AM
FastEddie's Avatar
No sand in the clutch at all. The rollers had turned and ground into the clutch.
Old Mar 18, 2004 | 12:06 AM
FastEddie's Avatar
OK now I am really out of it. I have 2 LT 80's with the same mods done to both. I just pulled the clutches on both machines. One clutch is perfect. The other one I had to pull apart at the dunes and install a new seal ( it was gone) and new rollers. Now after just a couple of rides the rollers are ruined and the seal is starting to rip. What is going on here.
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
