ok dumb ?? how do i test for spark?
hi, i cant get my warrior started...how do i test for spark? i thought you just take out the plug, put in the wire and start it and your supposed to see spark at the end of the plug.....is this correct? if this is correct, and there is no spark, what is the likely culprit on a 98 warrior...thanks alot for everyones help...
you unsrew the plug from the cylinder leave the wire on the top of the spark plug and just lay it against the cylinder in your view and turn over the engine and you should see a blue spark at the end of the plug, if you see a spark you have spark if you dont see a spark you dont have spark[img]i/expressions/face-icon-small-smile.gif[/img]
Ok, whatcha do, is you grab a hold of the plug, still in the plug boot and press the E-start button, this is a good indicator, lofl, jk, dont do it, it will shock the pi$$ out of you, my hand was barely touching the plug when my friend kicked it and man, it was shocking. Do what they said above.
Ha ha ha ha..........you beat me to it Hondaracer305!!!! I had a MSD 7AL light me off once; my friend that was there said it looked like I was praising the Lord!!! Both my hands were in the air waving around!!! Ha ha ha......
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
