ok dumb ?? how do i test for spark?
Old Mar 16, 2004 | 11:11 PM
loveMyYamahas's Avatar
Default ok dumb ?? how do i test for spark?
hi, i cant get my warrior started...how do i test for spark? i thought you just take out the plug, put in the wire and start it and your supposed to see spark at the end of the plug.....is this correct? if this is correct, and there is no spark, what is the likely culprit on a 98 warrior...thanks alot for everyones help...
Old Mar 16, 2004 | 11:12 PM
warrior68man's Avatar
Do all of that!!! Expect hold it near a piece of metal to see the spark...it shouldd be a nice blue spark...your frame or exhaust will work fine for holding it up against.
Old Mar 16, 2004 | 11:16 PM
WhiteBros440EX's Avatar
you unsrew the plug from the cylinder leave the wire on the top of the spark plug and just lay it against the cylinder in your view and turn over the engine and you should see a blue spark at the end of the plug, if you see a spark you have spark if you dont see a spark you dont have spark[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 16, 2004 | 11:17 PM
Outlawlawndragster's Avatar
Check all your switches wiggle them shake them . Also try a different spark plug I have seen plugs fail . Could be Coil or CDI HArd to pin point from here
Good luck
Old Mar 16, 2004 | 11:19 PM
hondaracer305's Avatar
Ok, whatcha do, is you grab a hold of the plug, still in the plug boot and press the E-start button, this is a good indicator, lofl, jk, dont do it, it will shock the pi$$ out of you, my hand was barely touching the plug when my friend kicked it and man, it was shocking. Do what they said above.
Old Mar 17, 2004 | 01:36 AM
Doctorturbo's Avatar
GOT BOOST!
Ha ha ha ha..........you beat me to it Hondaracer305!!!! I had a MSD 7AL light me off once; my friend that was there said it looked like I was praising the Lord!!! Both my hands were in the air waving around!!! Ha ha ha......
Old Mar 17, 2004 | 01:41 AM
trailrider500's Avatar
lol I know what you mean, I will never forget the night i upgraded the ignition on my mustang,,, wow what a shocking experience!!![img]i/expressions/face-icon-small-shocked.gif[/img]
Old Mar 17, 2004 | 02:13 PM
turtleboy660's Avatar
I have had almost the same experience.... where were checking a bunch of things on my friends topsportsman car thought we had a bad ignition box I was holding the coil wire next to the chassis and not paying attention when my friend did something with the 7al I couldn't let go of the wire and my arm and chest hurt for almost 3 days!
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Hatrackr
Aug 11, 2015 09:03 PM
Austins
Aug 9, 2015 02:28 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
