300EX Rear bearings need help
Old Mar 17, 2004 | 11:22 AM
BE20's Avatar
Default 300EX Rear bearings need help
Does any one know what are the dimensions or size for the rear bearings that would fit a LSR carrier on a 300EX? I purchased the quad as a restoration project and the existing bearings are such in bad shape that I am not able to retrieve the part numbers on the bearings or seals. I am trying to avoid purchasing seals and bearings from LSR at over a $100. I am also staying away from the cheap parts found on Ebay. People have mentioned that they have bought bearings from bearing dealers in their hometowns, I would like to do the same, thus no part numbers. The bearings are non-tapered from what I can tell, any help would be very much appreciated. Thanks!!
Old Mar 18, 2004 | 04:00 PM
95wolv's Avatar
You could always measure OD and ID with a dial caliper and take that to a shop and see what matches the bearings you have, bring the old ones to make sure that they match up.
STLyamwar
Jul 25, 2020 04:44 AM
Asaran
Oct 8, 2015 11:14 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Peter_
Jul 18, 2015 07:06 AM
