When to use Low????
Old Mar 17, 2004 | 08:11 PM
polarisman500's Avatar
Default When to use Low????
When would u use low on the sportsman 500h.o????
Also if u were pulling your kids on sleds behind the fourwheeler would u use low gear???
Thanks alot for your replys,
Robbie
Old Mar 17, 2004 | 08:29 PM
Polaridoo's Avatar
If you are doing extreme towing or going very slowly, I would use low. On the 700s, if you are hovering around the 7 mph mark for any length of time, Polaris reccomends to use low range. This is becuase at that speed you are very close to the engagement / disengagement of the primary. And that will cause plenty of heat / wear / and belt slippage. Spending enough time on the machine will probably teach you when you want low and when you want high. There are times when I can use high range to climb a really steep hill, but it just makes more sense to use low in those situations. When in doubt use low and if you easily max out the speed / rpms in low, then you know high would be a better choice (and vice versa)
Old Mar 17, 2004 | 10:16 PM
BT250racer's Avatar
polaridoo pretty much said it
