1998 sportsman 500 No spark
Old Mar 17, 2004 | 08:35 PM
FrankieT's Avatar
Default 1998 sportsman 500 No spark
I have no ignition spark,can any body point me in the direction to start looking for the cause?
Old Mar 17, 2004 | 11:04 PM
quadwrench's Avatar
Do you have a service manual for the quad? It is a very useful tool, especially in this circumstance.
The no spark instance is a very complicated means of testing - check the simple stuff first - - are you checking for spark with a new plug? Are there any obvious broken/torn wires? Have you shorted anything out?
Then you can get into component testing -
does the coil ohm out within specs? (primary - terminal on coil where blue/white wire connects to coil ground = 0.3 ohms) (secondary - spark plug cap removed - resistance from end of wire to coil ground = 6.3K ohms)
Then exciter and trigger coils - wires coming out of engine unplugged and measure resistance (on engine side connector) across:
red to green = 3.2 ohms (98 model)
black/red to green = 446 ohms
If these components are OK, then you most likely have a defective CDI module.
Hope this helps.
Jmuddin284
Jan 19, 2026 07:16 AM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 12, 2015 05:56 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
honda71
Jul 8, 2015 02:13 AM
