sealant for 2 stroke crank case?
Old Mar 18, 2004 | 06:16 PM
ScrambleMe's Avatar
Default sealant for 2 stroke crank case?
I noticed that it had a gray sealant when dis assembling. I have some dow corning 3145 gray and after contacting dow corning rep. they said "not recomended" I've been told to use "high temp red" but it says right on it not to use when part is in contact with gasoline. What should I use? What have you all used?
Thanks.
Old Mar 18, 2004 | 06:22 PM
Sundance's Avatar
High temp. RVT or Ultra Blue. It'll do the job better than anything else. I just put the front diff. cover back on my pick up with it. Find it at an auto parts place. Cheap too.
Old Mar 18, 2004 | 06:28 PM
ScrambleMe's Avatar
Ok, but the diff. doesn't come in contact w/ gasoline. Have you tried it on a 2 stroke crank case? Will it hold up to the fuel?
Old Mar 18, 2004 | 07:21 PM
HELIX's Avatar
The most common is a product called 3 BOND fron 3m...It is available at Yamaha dealers called YAMABOND(same stuff.I've used it for years,and so do many performance shops. Another common one is a locktite product that is like a purple goo that does not completely dry (loctite 515 ,i beleive)
Old Mar 18, 2004 | 09:59 PM
Chilly's Avatar
The ThreeBond is your best bet, it's what it is designed for.
Old Mar 18, 2004 | 10:10 PM
predatordude's Avatar
Polaris uses either 3 bond those guys mentioned or you can use Loctite Grey (##??)- get it a auto store, same thing pretty much, we use both in our shop.
Old Mar 18, 2004 | 10:30 PM
Polarisboy2's Avatar
Yamahabond. I know it hurts to put it on all the polaris motors I rebuild but the stuff is tough. At least Yamaha got there name put on something worth while. Jay
Old Mar 19, 2004 | 12:42 AM
JEFF10049's Avatar
Yamabond Is a good sealer and works well. I have also used a sealer called GASGACINCH It has never failed me either and comes apart alot easier next time.
Jeff
Divergent12
Dec 30, 2017 08:33 PM
SDR-II
Sep 29, 2015 01:06 AM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
