sealant for 2 stroke crank case?
I noticed that it had a gray sealant when dis assembling. I have some dow corning 3145 gray and after contacting dow corning rep. they said "not recomended" I've been told to use "high temp red" but it says right on it not to use when part is in contact with gasoline. What should I use? What have you all used?
Thanks.
Thanks.
The most common is a product called 3 BOND fron 3m...It is available at Yamaha dealers called YAMABOND(same stuff.I've used it for years,and so do many performance shops. Another common one is a locktite product that is like a purple goo that does not completely dry (loctite 515 ,i beleive)
Yamahabond. I know it hurts to put it on all the polaris motors I rebuild but the stuff is tough. At least Yamaha got there name put on something worth while. Jay
