RECON BACKFIRES
Old Mar 18, 2004 | 07:49 PM
A6079C's Avatar
Default RECON BACKFIRES
my 1997 recon has been sitting for a few years and i have been trying to get it running again. when it starts it runs rough but it will idle. if i can get it moving fast enough to get the rev's up it seems to run well but when i get it moving and let off the throtle it has small backfires creating a small flame coming out the exaust. it has never been serviced and i was thinking about checking the valves but i don't know the what the clearance is. i am also looking for the stock idle screw setting and the setting for the air/fuel mix screw.
thanks,
andy
Old Mar 18, 2004 | 08:04 PM
Polaris500HO4x4's Avatar
the backfiring could be coming from a small crack in your exhaust causing suction then your engine will fire and it will back fire probablly because it doesnt idle so great yet/
Old Mar 19, 2004 | 02:00 PM
hondabuster's Avatar
Youre lean on the idle circiut. Most likely the pilot jet is partially obstucted, by dried out gas. Try going richer ( out) on the mixture screw, about 1/2 turn. Could also be bad gas, try draining out the old stuff and put new fresh gas in.
Old Mar 19, 2004 | 04:34 PM
A6079C's Avatar
is there a way to clean the pilot jet without removing the carb?
Old Mar 20, 2004 | 02:54 AM
You could try, but I dont think itll be sucessful. Drain out all of the old gas, and put new gas in, and put some carb cleaner, or sea foam in the gas. But once theres an obstuction in the jets, it needs to come apart to get it clean enough so it doesnt plug up again.
Heres a couple of links about carb cleaning.
carbclean
carb
Old Mar 20, 2004 | 03:19 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Buster-The links aren't working for me. Can you give the addresses? Thanks!
Old Mar 20, 2004 | 03:29 AM
Sure,
http://www.atving.com/editor/techtips/carbclean.htm
http://oldmanhonda.com/MC/Rcarbs.html
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
alzgarvin
Sep 11, 2015 08:53 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Brandon400
Sep 7, 2015 12:20 PM
