really STUPID oil question, 400EX
Old Mar 22, 2004 | 10:26 PM
raptor5k's Avatar
Default really STUPID oil question, 400EX
Alright i can hear the snickers already! Anyway today i went and checked my oil in my 2000 400 EX, and i could barely even see any on the dipstick. This is a problem. So what oil should i put in?? just some 10W40 or what?? stupid i know, i just don't like to take chances w/ my baby!
Old Mar 22, 2004 | 10:32 PM
jim450r's Avatar
take chances??? i think not checking it may have been a chance....and if its ur baby i think u woulda checked....anyways i have forgot b4 too! but if thats all u have u can...but the honda shop will have the oil designed for it...
Old Mar 22, 2004 | 10:40 PM
Ish416's Avatar
Did you check the oil after the engine was warm? That is when you need to check it. There usually isn't any on the dipstick if the machine is cold.
Old Mar 22, 2004 | 11:04 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
http://www.thumperfaq.com/oil.htm
Any JASO MA oil. Your owners manual recommends Honda GN4 (dino oil) or HP4 (dino/synth blend). I run HP4 in my 400's. How long have you had this machine? You are just checking the oil now? I rarely go more than 20 hrs without an oil change, and usually more like 10 hrs on the sport bikes. If you want your baby to last, frequent oil changes are the way to go!
Old Mar 22, 2004 | 11:39 PM
Spudss's Avatar
I run the Bell Thumper oil in my 400 and it is very good stuff. Kinda pricee but I would rather spend alittle extra now than a whole lot later....I would suggest a good Synthetic Blend 20-50 That weight covers most elements depending on your location...
Old Mar 23, 2004 | 09:08 AM
dzzy's Avatar
400EX is a dry sump engine, it has a special checking procedure. Not just when the engine is warm, you must allow it to idle, without blipping the throttle, on level ground for 3 - 5 minutes. then wait just a couple minutes and check. CHECK your manual for the procedure if you want the right amount of oil in your machine.
Old Mar 24, 2004 | 03:08 PM
Hondanutcase's Avatar
Yes do this. You cannot check your oil enough!!!!!!!!!!!!!!!!!!!!!!!!
1ArmBandit
55
Oct 14, 2015 09:03 PM
bigred20653
Oct 2, 2015 10:05 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
