je piston
Old Jul 14, 2000 | 10:57 PM
ogre's Avatar
quick question - I just got my je piston today, I wanted to be sure about mounting the piston. The arrow should point toward intake, correct? I can see on the top of the piston the size difference between the intake and exhaust valve clearances. I just wanted to double check.
Thanks, ogre
Old Jul 17, 2000 | 11:17 AM
SNELL's Avatar
I'm not sure of the direction the arrow is suppost to go, but make sure you check valve clearance because I just got a TC cam and 87mm JE piston for my 400ex and the valve reliefs in the piston were cut wrong from the factory so I had to have the piston sent back.
Old Jul 17, 2000 | 11:46 AM
ogre's Avatar
You need to know which way the arrow should point because the valve relief on the intake side of the piston is smaller (diameter); obviously, because the diameter of the intake valves are smaller.
This brings up a quick question; I will be reassembling my 400 soon, how can I be sure that my valves will clear my piston? Manually turn over the motor and listen? I'm sure they will, I have an 87 mm 10.5:1 je piston w/o a cam upgrade, but I've never upgraded a 4 stroke with an aftermarket piston.
Thanks, ogre
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
