need help with an 84 honda 200s
Old Mar 28, 2004 | 11:59 PM
pondrunner's Avatar
Default need help with an 84 honda 200s
I have a hgnda 200s and its wont start. it doesn't even get spark. I think it might be the coil. I thought I what yall had to say about. And if anyone has a coil that <u>works</u>. Please inform me about it.
thanks,
Old Mar 29, 2004 | 12:23 AM
sharpie's Avatar
theres alot of reasons why it might not start.
1. check kill switch
2. pull the plug, plug it back in to the wire and lean it against the block and see if it has spark.
3. clean the plug. do a good job of it.
4. check if the angle piece that hooks on to the plug from the wire. they can come loose. make sure that the wires in the end of the plug wire arnt rusted or broken.
5. trace the wires. start with the wires from the kill switch. take it apart because they can come loose inside. follow them and check all the connections anywhere.
6. at this point you might want to make sure that the engine is generating electrisity. might be handy to have a VOM.
7. finally, if everything else looks fine, check into gettin a coil.
hope this helps out. good luck.
Old Mar 29, 2004 | 12:27 AM
pondrunner's Avatar
it aint the kill switch, plug, wires. but it won't spark. Im worried that its something big
Old Mar 29, 2004 | 12:40 AM
sharpie's Avatar
you might check inside the headlight housing. i think that theres connections in there. you might also check the spark plug wire. jsut feel all the way down it. if thers a break in it it will bent reel easy. if it is then you should look for a new coil. it happens.
scman843
Jun 18, 2017 10:21 PM
theddaug
Aug 15, 2015 09:17 AM
95wolv
Jul 17, 2015 08:13 PM
timster911
Jul 13, 2015 01:57 PM
