how to jump
can some one tell me the steps to jumping a dirt bike in detail or a quad in detail i dont know how to preload the suspention all i can do is go fast and hit it and pull up and get like 2 ft of air a guy next to me on the same jump was going slower and got like 15-20 ft what do i need to do this is for a dirtbike or a quad i have bothe and need to learn how to on both thanks for your info
I'm a slow and bad typer so I send you to the right place
http://www.douggust.com/content/Race.../prof_gust.htm
Originally posted by: slidesquad
thanks for the link but it didnt help me 2 much
how do you preload you suspention befor the jump?
When you're just starting out with pre-load, keep it even from front to back. Later, there may be times when you want to preload the back more, or the front more. For example, when you going over a short double-jump, you may want to pre-load the back shock more so that the back end hops up higher than the front. This would put you at a down-ward angle to match the landing ramp. If you're going for a step-up double, you may want to pre-load the front more so that the front of the quad stays higher to match the upcoming plateau.
Getting the feel for this takes practice. In a controlled setting, try pre-loading different ways to learn how your quad responds. The most important thing is to keep the rubber side of the quad pointing down...
this is from that site. http://www.douggust.com/content/ask_menu_riding.htm
hey thanks for the info would you happen to know one more thing the little screws on my front suspetion tops what do they do and how do you adjust it i know it dose somethin lol thanks for all the info
