02 Grizz jerks
My new-to-me 02 Grizz jerks when slowing from moderate speeds and only using the back brakes. Is this normal or is it a problem? Doesn't do it when coasting down or using front brakes. Does anyone else's Grizz do this? BTW mine doesn't have the override button like I saw in the 04 catalog. Whats that for? Any help appreciated. Thanks, Jed.
don't know about the jerking, maybe the brakes need some braking in (no pun intended) about the override button, if it's the one i'm think of on auto trannys it allows you to go as fast in reverse as you can in forward.
hope i helped
hope i helped
It's normal. it's just play in the rear driveline, when you slam on the brakes, it will jerk and clunk. took me by suprise the first couple times... also. SOME of the grizzly's have a problem with the rear disc brake bolts coming loose. It will make more noise, and COULD break the bolts... I haven't seen any that have broken any bolts, just FYI that i could happen. Mine have been tight since day one, my buddies were a little loose at about 2000 miles...
